    Dismiss Notice
what fall does the line on a spirit level either side of bubble covert to.
Discussion in 'General DIY' started by zuber ali, 20 Aug 2021.
  1. zuber ali
    zuber ali
    30 May 2021
    62
    Thanks Received:
    Country:
    hi all trying to work out falls and depths for my patio, from my limited knowledge i understand if i have a gradient on my spirit level so that the bubble slightly passes the lines either side, this should be a sufficient fall, i would like to know what fall does this actually convert to i.e 1 in 100, 1 in 60 etc.
  2. RandomGrinch
    RandomGrinch
    15 Jun 2021
    750
    Thanks Received:
    147
    South Wales
    Country:
    Find a straight and level surface, lift one end of your spirit level until the bubble hits the line and measure the distance the end of the level is from the ground.
    Divide this distance by the length of your level (in the same units) and you have your fall.
    If there was a standard for these lines, it is probably worth doing this anyway. Many cheap levels I have had, strongly disagree with each other :)
  3. Sponsored Links
  4. foxhole
    foxhole
    14 Mar 2006
    17,853
    Thanks Received:
    2,049
    Kent
    Country:
    Levels vary. Plenty of mobile phone apps to give you the fall . You can use a line set to fall you require for level.
    • Like Like x 2
  5. cdbe
    cdbe
    22 Nov 2009
    1,331
    Thanks Received:
    240
    Oldham
    Country:
    It doesn't matter, you don't lay a patio to fall by levelling individual slabs with a spirit level. You lay them to a line with the fall set using a spirit level set level on a straight edge and a tape measure to measure down.
  6. Sponsored Links
  7. zuber ali
    zuber ali
    30 May 2021
    62
    Thanks Received:
    Country:
    Oh yeah I should have thought of that. Thanks
Loading...
Share This Page
