What is part P?
11 May 2007
Kent
I have a wayward electrician, but my builder wont get rid of him because "I won't be part P certified". I this nonsense. Surely I can just get another compliant electrician to finish the job off.
Part P Approved Document
If the work has been started its unlikely that another electrician will sign off that work as his own.
Has first fix begun? Are the cable runs still visible? Why are you concerned about the electricians work?
We have all the cabling in place, from the boxes in the kitchen to dangling wires in the garage (where the fuse box is located). Still, nothings moved for a while and I'd like to know I have the option to get this guy out of here and not be held to randsom with the part p threat.
As Davy says, Part P regs do not allow an electrician to sign off another's work as their own. However, if they can get access to the cabling to test, etc. you may find one willing to do it (assuming it has been done correctly of course!).
Your other alternative is to involve Building Control, as they can inspect and sign off anyone's work as compliant. They will charge for this, but may be worth it if you really want to get rid of the current spark (what's he done/not done?).
If Building Control are already involved because of other work the builder is doing, then they should inspect the electrics as part of the entire job WITHOUT charging extra (although it appears many try to charge extra).
Gavin
Then get rid of your builder first. :idea:
