What Plumber/Gas Engineer Is Right?!
Discussion in 'Plumbing and Central Heating' started by Bakeyournoodle, 13 Mar 2014.
  1. Bakeyournoodle
    Bakeyournoodle
    13 Mar 2014
    2
    Thanks Received:
    Southampton
    Country:
    Hi there.
    I've having a problem with my Potterton Prime 50F boiler - it is quite old, but have served us well so far.
    So in short... it doesn't quite start properly. You hear the fan whirring, but it takes a few clicks and cycles until the flame eventually starts. It then goes on for around 2-5mintues, before i hear lots of bangs and it stops.. it definitely is overheating/kettling?
    Now, I know the pump upstairs needs replacing, but I've had two gas experts come in with different conclusions on the boiler.
    1) the flue & fan needs replacing
    2) the pcb needs replacing....
    Can anyone tell me which one is the most likely cause? :eek:
  2. newbuildinstaller
    newbuildinstaller
    3 Jun 2010
    7,555
    Thanks Received:
    1,674
    Durham
    Country:
    if the pump needs replaced....
    REPLACE THE PUMP
    and see where you stand
    • Thanks Thanks x 1
  3. Sponsored Links
  4. neiltheplumber
    neiltheplumber
    13 Feb 2011
    668
    Thanks Received:
    108
    Birmingham
    Country:
    Pump for me too! If it's banging its probably because the heat cannot be moved from the boiler quick enough which results in banging because the water is literally boiling/kettling. Also a dirty system can cause the same problem and therefore the boiler will struggle to push the heat around the heating system.
  5. GavThePlumber
    GavThePlumber
    28 Sep 2013
    534
    Thanks Received:
    74
    Country:
    Is this another troll account?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
