What pump to boost domestic hot water flow??
2 Jun 2005
West Midlands
Hi Guys.........what is the best option in the pump department for boosting the domestic hot water supply pressure. The mains cold water supply is adequate as it is. It is a gravity system with a 5' head.
Any advice will be gratefully received
Can I take it that shower pumps would not do the job? And what happens to the flow/return that is not used if it is only the hot water that needs boosting??
If your only boosting the hot use a single pump not a twin.
