Hello all, I hope someone can help. I have ordered a new box profile roof for my garage from a company called planwell. The roof is flat with a slope from front to back.
My plan is to rip of the existing asbestos/concrete curregated panels, lay OSB3 board down on the top of the purlins, felt over the top then screw my steel roof and flashings to the OSB. Then on the inside I will insulate under the OSB with standard glass fibre and install a plasterboard ceiling.
My question is what would you recommend in terms of felting? Should I use a few layers of shed felt glued with bitumen or would a few layers of membrane suffice? If membrane is ok then how should it be fixed to the board.
Here are a few pics of the garage. My aim it to make it draft free and relativly warm.
