Where can I get 20mm MDF?
MDF usually comes in either 18mm or 25mm, you can get small sheets of 18mm in places like B&Q, you will have to get the 25mm from a timber merchant and it will be a 4ftx8ft sheet.
Jason
Depending on what you need it for, Wedi board might work... they make a 20mm - Wedi.co.uk
Hope this helps
The only way I know to get 20mm MDF is to laminate 8mm & 12mm boards together.
only problem with that is where do you get 8mm MDF from Dewy?
I though two sheets of 9mm with a sheet of 2mm in the middle as I know where to get both thicknesses from.
Jason
