Whistling TRVs
11 Aug 2008
Hertfordshire
I have a sealed central heating system with TRVs on all but one radiator. Radiators are on 10mm plumbing. When the room temp is getting close to the TRV setting, the radiators make a really high-pitched whistle, sometimes for many minutes before the TRV shuts off the radiator. It's definitely the TRV causing this, as I can stop it by adjusting it either up or down a small amount.
Is this symptomatic of any problem? Is there a way to stop it?
Your pump speed is too high, turn it down a bit. May also be cheap TRVs that are vibrating, in which case better TRVs will help
As far as I know, all modern TRVs are bi directional. it is worth checking for an arrow on the valve body. There should be 2 arrows. If only one, then they have to be fitted on the flow.
I have had noisy TRVs which benefit from being switched over to the flow.
