breezer said:detectors must be on their own circuit
Can you multiply 3 x 3? Is the answer 3?diyer001 said:If the rating for a device is 3amps and say you have three of them. Can you use one 3amp spur box to connect all of them or do you need a separate box for each?
PIR stands for Proximity Infra Red - it detects warm bodies, not humidity...JPBOLDY said:you can get others without a timer or with a PIR sensor which come on when they dectect humidty levels
It never ceases to amaze me how many people put down immovable floors, install new bathrooms and kitchens, finish off all the decoration, and only then think about the wiring....If anyone has any ideas how i can wire up a extractor fan in my kitchen would be great - one problem is that i cant connect to the light fitting cause we have wooden floor down and has just been fitted, also the vent is above the window that i wanna use and without hacking into the wall to route to the light switch would be amajor task and cost as kitchen just been done as well, installing the fan wouldnt be a problem its just the wiring side
ban-all-sheds said:PIR stands for Proximity Infra Red - it detects warm bodies, not humidity...JPBOLDY said:you can get others without a timer or with a PIR sensor which come on when they dectect humidty levels
Err - yes, it does, doesn't it, 99.99% of the time. Sorry 'bout thatbreezer said:sorry ban it doesn't, it stand s for passive infra red.
