    Dismiss Notice
WIRING A CONTACTOR
Discussion in 'Electrics UK' started by poolcool, 13 Aug 2006.
  1. poolcool
    poolcool
    13 Aug 2006
    4
    Thanks Received:
    Plymouth
    Country:
    :rolleyes: i HAVE JUST INSTALLED A PUMP FOR MY SWIMMING POOL BUT CANNOT WORK OUT HOW TO WIRE IN THE CONTACTOR, ITS A CONTACTOR THAT LOOKS JUST LIKE AN mcb AND HAS TERMINALS ON TOP MARKED a1 r1 1 ON THE BOTTOM IT HAS TERMINALS MARKED a2 R2 2 CAN ANYONE PLEASE TELL ME HOW TO WIRE THIS IN PLEASE.
    ______________________________
    Lynda, moderator,
    please note forum rule 6
  2. Sponsored Links
  3. fireman22
    fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    what it the contactor controlling
  4. poolcool
    poolcool
    13 Aug 2006
    4
    Thanks Received:
    Plymouth
    Country:
    IT I BELIEVE JUST LESSENS THE LOAD ON START UP OF THE PUMP THE PUMP IS MAX 1.9KW AND THE CONTACTOR CAN HANDLE UP TO 3.5KW DO YOU KNOW HOW TO WIRE THIS IN PLEASE.
    Lynda, moderator,
  5. fireman22
    fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    no the contactor coil just takes less current that your switching circuit can handle, with the contacts of the contactor rated higher for the higher load you may put on it. anyway how are you planning to switch on this pump? i am refering to how you are going to pull in the contactor
  6. poolcool
    poolcool
    13 Aug 2006
    4
    Thanks Received:
    Plymouth
    Country:
    THE SUPPLY COMES FROM THE MCB 10A TYPE C ,TO A SWITCHED FUSED SPUR TO A MECHANICAL TIME CLOCK THROUGH THE CONTACTOR AND DOWN TO THE PUMP. BUT THE TERMINALS ON THE CONTACTOR CONFUSE ME AND IM NOT SURE HOW TO CONNECT THIS IN.
    Lynda, moderator,
  7. fireman22
    fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    right yes the terminals on the time clock are probably lower current rated than than the pump hence the contactor. well a1 and a2 are the coil of the contactor positive and negative. if you put 240 volts accross these terminals the contactor will pull in and the R1 and 1 terminals will then be connected to thr R2 2 terminals (double pole switch) just use the timer to power the coil then switch power to the pump through the R1 R2 1 2 terminals.
    i am assuming the coil is 240 volt ( stop typing in capitals someone will give you a row)
  8. poolcool
    poolcool
    13 Aug 2006
    4
    Thanks Received:
    Plymouth
    Country:
    Thanks for that it is greatly appreciated "just read the rule 6 and my appologise for what is considered shouting this was unintentional" Again thanks :D
    lynda, moderator
    thanks
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
