Wiring a lighted bathroom cabinet
13 Apr 2007
Essex
I have an old transformed shaver socket exactly where I want to put a new lighted bathroom cabinet.
What is the correct way to take the supply out of the wall?
Do I need a waterproof FCU? Will an ordinary FCU do? Or is it some other thing altogether?
I already know this is notifiable.
regards
Adrian
Your shaver point will have a large box.
Asssuming the shaver point is on the lighting circuit (most are), connect the wires from the cabinet to the existing wires using a piece of terminal strip.
If the above is true then you do not need an FCU. I would question if its notifiable as you are not changing the fixed wiring, only an accessory attached to it. Unless you are doing other electrical work there too???
