I am installing a new kitchen and need some help with wiring a new electric hob and cooker.
I have 6mm square wire coming from my consumer unit and that connects to a fused box with plug socket above the units.
I have then run the same size wire down to a terminal box near the rear of the oven.
The hob is rated at 230V 50Hz and 6.4 kW.
The cooker is running of a 13 amp plug.
I have run a single socket from the terminal box behind the oven for the oven to be connected to so that it is fused via the plug.
The hob was going to be directly wired using 6mm square wire to the terminal box.
My only issue is whether this is acceptable tacking into account that the maximum power running through the 6mm square cable is around 9.4 kW.
