WIRING A PLUG
29 Jan 2007
Hampshire
I have just purchased an old lamp, however the cable does not have the usual colourings for when it comes to attaching a plug, one wire is black, one is silver and the other is yellow/green stripes, would be grateful if anyone can advice me on this one.
Is it an American lamp? Does it have a switch on it? Is it a metal casing?
Is it possible to completely replace the cable? If not, bell the cables out and sleeve with the appropriate LNE colours
I don't really want to replace the cable as it is an antique. what do you mean by bell out the cable?
A continuity test from one end to the other to hopefully establish where they go (unless they're broken!). If it's really old then the insulation on the cables may be poor, so you'd be best to put a new one on.
I should have said change the flex.
"belling out" will be of little use, since it will not show the insulation resistance, hence change the flex.
One question no one has asked.
this silver core, is it actual silver metal you can see or is it silver coloured insulation.
a pic would help. pic info is in forum information
oh, dear. is sonds like its so old is detear, oh s*d it, broken down .
also the flex has been changed before since one core is green and yellow
any chance of a pic to be 100%
