I would be grateful of some advise please.
I need to fit a hob and double oven in my new house. The old hob was fitted to a cooker switch using 6mm cable from the CU on a 30amp fuse.
I have isolated this and the hob is the only thing on this circuit.
The old cooker which was rated at 2.70W was on a 3 pin plug, plugged into the ring main.
I understand that I can wire the Hob into the cooker switch box using 6mm. cable. Can I run a feed from the cooker switch around to the oven using 6mm? So in other words both the hob and the oven run from the cooker switch.
The distance from the CU to the Cooker switch is about 10 to 12m and the distance between hob and oven is no more than 3m.
The ratings for the new equipment are
Hob 7.2kW max total amps 30 min fuse protection 30A
Oven Max Load 4410 W
I hope this is a clear explanation of what I'm trying to do!
