wiring interlinked mains smoke detectors
5 Jan 2004
Excuse my stupidity, but can i connect 4 mains powered smoke alarms on a spur off the lighting circuit or mains ring? or should I put them on their own supply?
Thanks for the help
Tom
do they HAVE to be on their own supply? I called 3 sparky's today, they all wanted about £150 just to connect to the consumer unit providing I had wired in the cable everywhere for them. I guess its not that hard to connect a circuit to the mcb at the unit, is it?
I just thought that connecting to the lighting circuit would be easier for me. Would the building inspector check that they are on their own circuit(currently converting my loft, B.Insp said i must fit the alarms)?
Can you ask the building inspector why? I have done a few loft conversion and never been mention on the drawing plan I've done.
dont quote me but i thought it was part of the new building regs.
_____________________________________________________
yes they shuld be on thir own supply so they will not be turned off with soething else.
if you can connect them to the lights yo should be able to connect thenm to the consumers unit, just take CARE
Cheers guys, I'll let you know if i electrocute myself. And you are right breezer, its part of building regs, i have to have at least one on every level of the house.
Thanks again.
Tom
They should not be on there own supply.....reason being if they were faulty (sounding off) you could isolate them, not very safe......but if they were on the lighting circuit....well you know its going to be dark if you tried to isolate it.....oh yes and interlinked
it would seem we are both right, depending on TYPE of smoke alarm.
if it has a battery back up it can go on with the lights, if it has NO battery back up then it can't
