Hi there
I followed the instructions of a friend a while ago as how to repair the led lights in the kitchen from the attic. I connected the transformer to the existing wiring using a piece of normal plug cable. I did this with a set of terminal blocks and wrapped them in insulation.
I want to revisit this so I can took the wiring under the insulation in the attic. Is it safe to do so now or should I replace the terminal blocks with something else?
