Woodburner flue height
16 May 2004
Edinburgh
Just a quick one. I can't find the required dimmensions for chimney height. I think that if the chimney is under 1500mm horozontally from the apex it must be 600mm higher than the apex and if it is under 2300mm from the apex it must be as high as the apex. Is this broadly right. I know i once found a link which explained it but I cant find it now.
David
Just look up www.odpm.gov.uk and see building regs. Then ignore what you are ALLOWED to do, and build the chimney much higher than the ridge. If you look at old houses you will see chimneys are higher than the ridge,....not for nothing was it done this way. Many problems are caused by short chimneys.
Refering to page 26 of
http://www.odpm.gov.uk/stellent/groups/odpm_buildreg/documents/downloadable/odpm_breg_600285.pdf
The horozontal distance from the apex to the chimney is 1500mm therefore the chimney height should be just above the apex to meet the regs, but should be 600mm? above to give a flue that will work? On paper I think that the height from the point where the chimney breaks through the roof to the apex will be 1000mm, therefore an additional 500mm length should be close to the 600mm above the apex. Does this make good sense?
David
The best people to speak to are Euroheat (they have a website) they are frequently having to sort out chimney problems, and they produce probably the best designed domestic woodburner available.
