woodburner
31 Dec 2010
Pembrokeshire
hi dont know if this is the right place to post this but here goes, i need to replace a damaged enamel flue pipe on top of a stove i am going to use fire cement and glass fibre rope but there is not enough clearnce around collar to fit/stuff it down /around sides of pipe, so can i sit it in bottom of collar and seal with cement? then smoke test,thanks in advance.
I only use the glass rope when the gaps are too large, and the fireclay cement drops through.
Cement on its own will do fine here, and it moulds very well when dampened.
John :)
John :)
thanks burnerman, it also has a rear outlet which has never been used should i reseal this as ive got it out? and where it goes through the wall what should i seal it with it was just rendered and skimmed.
You can normally leave the rear outlet alone so long as it hasn't been messed about with - they usually have their own gasket seal.
As for the outlet through the wall, fireclay cement is fine here too (nicely smoothed with a finger) but gun applied intumescent sealants are available (usually white). Silicones wouldn't be used here.
John :)
John :)
thanks again.
