    Dismiss Notice
Wooden Floor help
Discussion in 'Floors, Stairs and Lofts' started by Alpaca, 28 Aug 2013.
  1. Alpaca
    Alpaca
    28 Aug 2013
    2
    Thanks Received:
    Country:
    My wooden floor had some scrapes so I attempted to sand it down.
    However, after sanding it down, I am finding it hard to figure out how to restore the finish. I cannot remember what species of wood the floor is made of. I think it is birch but had trouble finding a birch woodstain. I used a 'Light Oak' woodstain but the result was far from ideal, what you can see the image.
    What is the best strategy now in order to save the floor?
    All advice appreciated.
  2. Sponsored Links
  3. jay679
    jay679
    3 Jan 2013
    158
    Thanks Received:
    24
    Yorkshire
    Country:
    Are those stains, or low spots where the sander hasn't removed the top surface?
  4. Alpaca
    Alpaca
    28 Aug 2013
    2
    Thanks Received:
    Country:
    Those are the areas that I sanded, and tried to re-stain with the Light Oak woodstain.
  5. i_am_fubar
    i_am_fubar
    1 Oct 2007
    605
    Thanks Received:
    21
    Hampshire
    Country:
    Hate to say it, but the only way you will get a consistent colour now will be to sand the lot and re-stain.
    Hire a floor sander if it's a big space and you can afford it.
    Nifty tip if you ever have scratches again. Try rubbing a walnut over them, the oils frequently make the scratches invisible.
    Fubar.
  6. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    That's what it looks like to me. Needs re-sanding to take another few mm off.
    Cheers
    Richard
  7. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    I'm almost certain it's not a stain. Running a finger over it would confirm, but I think it's low spots in the floor caused by furniture or footfall. The sander has flattened the floor around them but the dips remain. It's what the surface of the rest of the floor would have looked like before sanding. I saw a similar effect when I sanded one of my floors.
    Depending on how deep this is, you might be able to get it with some localised sanding with a belt sander, being careful to feather out to the surrounding floorboards, so the difference in level wasn't too noticeable. Or sand those areas by hand.
    I wouldn't suggest staining without sanding, as it won't come out the same colour as the rest of the floor.
    Cheers
    Richard
  8. JasonF
    JasonF
    2 Jan 2012
    80
    Thanks Received:
    8
    West Midlands
    Country:
    Carpet
  9. Corazones
    Corazones
    6 Jul 2004
    165
    Thanks Received:
    10
    Sussex
    Country:
    Are you sure the floor was stained in the first place? It may be natural darkening, or the effect of oiling or clear varnishing. I suggest a bit of detective work first - try scraping the surface of a corner and see if a layer flakes off, and compare it with the wood below. If the floor was oiled (you may be able to smell this), then the "stain" could be water marking.
    Alec.
  10. Sponsored Links
  11. aclifford
    aclifford
    15 Jan 2014
    8
    Thanks Received:
    London
    Country:
    To reduce sanding infections, you need to 'pop the grain'. Popping the grain is easy and is done by getting the floor wet before standing in order to open the grain of the wood back up after the final sanding. Wood absorbs a greater amount of stain when the grain is opened. Contractors often stray the floors with a pesticide sprayer.
  12. Bosswhite
    Bosswhite
    15 Jun 2012
    2,898
    Thanks Received:
    405
    Southampton
    Country:
    Years ago I was discussing this problem of sanding floors and restaining with a collegue in the carpet trade, he said exactly the same thing,
    People spend a fortune on hiring equiptment or getting a firm in to do the work and it never looks the same again, he reckoned within a year people came to his business to have the floor carpeted.
  13. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    Personally I like sanded floors with strategically places rugs and carpets. They look so much more elegant than wall to wall fitted carpets, and carpets that can be taken up and properly beaten don't harbour dust and mites in the same way. It's also easier to change things round.
    I wonder if the OP sorted out his problem? The photo definitely showed unsanded dips in the floorboards.
    Cheers
    Richard
  14. jrh14
    jrh14
    17 Jan 2014
    31
    Thanks Received:
    6
    Tyne and Wear
    Country:
    Hello,
    What I would suggest is rent a sander and sand the whole floor down. Then re-stain.
  15. trent78
    trent78
    12 Feb 2014
    15
    Thanks Received:
    California
    Country:
    Hardwood floors are a big draw, and they're worth whatever rehabing you have to do to them. Once you resand and stain, think about laying down the best sealant and high-gloss shine you can. The more that floor looks like a basketball court, the more you, your guests or tenants or appraisers or buyers will like them. Totally worth it.
  16. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    Eek.
  17. GG123
    GG123
    15 May 2014
    8
    Thanks Received:
    Country:
    Hire a floor sander - should do the job!
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
