worcester 24i junior water too hot
8 May 2011
hi all,i have a Worcester 24i junior boiler,had no problems before with it ,but this week noticed the hot water was much more warmer than before, if I run the hot water the water is very hot and the boiler has to be reset yet if I only run the water at a trickle it does not cut out,the c\h is all ok and the pressure is all ok.can anyone help many thanks.
Presuming you are talking about the older 24i junior rather than the greenstar version? you really need to call an engineer asap as it seems you may have excessive gas pressure when the boiler is firing at maximum rate in hot water mode. The fact that the boiler does not trip to overheat when you turn the flow down on the hot water tap suggests this may be the case. Could be down to a few other probs as well but all need to be checked by an rgi.
