Just moved into my new home, tried setting up central heating and now i cannot see the pilot on the worcester 24i rsf Combi and i now have no Hot Water or Central heating. Can anyone please help before i freeze!!!
All i did was move the settings from just the h/w to 1 flame on the radiator change and put it on AUTO for the timer. I may have accidently put it on 0 but i checked it early this morning and forgot what it was on. I have set it to how it was previously and no luck.
I have also followed the manual to reset the boiler, no luck.
I have looked at the cooker just incase if it was a gas problem but thats fine. I havent though checked if the flame flickers if i try to turn the boiler on.
Pressue is on 1.5.
Any advise would be great and thanks for getting back so soon
Have you accidentally turned the switch off at the fused spur next to the boiler, light switch size possibly with red neon on it ?, maybe knocked it off with kettle or box or something moving in !
Your gas pipe from meter to boiler is inadequately sized. You need a Registered Gas Installer to check the gas pressures. However this does not explain the immediate problem you have with the boiler.
As Tony said you had best switch it off and seek help the flame at the cooker should not alter when the boiler is lit and on full let alone when its trying to light on min
