Worcester 28i Junior NEST wiring Please Advise
11 Oct 2014
West Lothian
Hi All, I am new here, I've spend most of the day to search how to connect my 28i to Nest, Could someone please shed some light here and tell me if my understanding is correct?
here is a photo of my Boiler connections,,
LS to Live Terminal
NS to Neutral
LR to Call for Heat
Link live with Common
and now as you can see on the picture there is a link between LS and LR on the boiler would that stay?
Would that be alright??
at the moment there isnt any thermostats connected at all, just this mechanical dial...
So if this is correct would i just need a 3 core wire and just matter of connecting it all together? please advise, and thanks in advance
Regards Martin
View media item 83852 View media item 83794 View media item 83853
as far as i can tell, the L and N to provide power for nest should come from the L and N the flex is connected to, or ideally from the isolator to the boiler
terminals 2 and 3 on the nest should be connected to the two terminals with the short jumper wire connected across them, after removing the jumper wire entirely.
It's easy to wire up.
Pick up phone....dial a nest pro installer.....requested visit. Get visit,...get nest installed....pay contractor....happy nest use.
Regards, a contractor.
or that. i'm swithering between the nest and the tado, either way i'll fit my own. really isn't hard to do. the guys who fitted my boiler recently told me which bits to connect the nest to, as i told them i was probably going with the nest, but didnt have it yet.
I've got one coming off the wall in my house, only 2 months old.
They really arnt all that. Pretty though.
thanks for the reply all, mine is coming from Amazon today, so gonna try to wire it myself,,, Just need to pop in to Maplin and get some wire...
So yeah i'll get the power connected to the isolator, and connect the rest of them, thanks scotsgraeme for the answer, so just to clarify,, In the boiler link between LS and LR need to come off permanently? and create a link inside the heat link between Common and Call for Heat? So no link between Live and Common?
Reason why i am asking this... https://community.nest.com/thread/4616
someone was hooking up 38cdi Worcester and this is what the guy advised to do,,, seems like most of these brand boilers gets connected(might be wrong) same way...
