Worcester 28i Junior
14 Nov 2011
Manchester
After having some bursts repaired the plumber was not able to refill the boiler as the key had been lost. I have now bought a new key, filled the system, bled the radiators, they all heat up, but the boiler pressure gauge is showing no pressure. Could there be an air-lock somewhere? What do i need to do? :)
Did you recharge/ fill the system again after venting/bleeding the rads?
Thanks, bster, will try that 2mz, got into such a loop with things i will start from scratch again. Will let u know, thanx again for reply!
Sounds very technical, how do i do that? Thanx.
But, having re-checked the pressure gauge i thought was on zero, on closer inspection it has gone all the way round the dial to 4.something. how do i lower the pressure?
