Worcester 30si water pressure
13 Sep 2010
Bradford
Can anyone please tell me how I can repressurise by boiler.
The heating has gone off and the boiler is making gurgling noises and the pressure gauge is at zero.
I've read threads saying that repressurising has solved the problem but i don;t know how to.
Oh it's all my fault according the misses
Do you have a leak?
Your boiler may have been fitted with a worcester integral filling link.
Its a small black plastic linkage between the return and cold inlet connections under the boiler. You need the white plastic key which should be clipped to the plastic cover under the boiler. The key is inserted upwards into the link and turned. It needs to be pushed in fully at the correct angle before you turn it. The white plastic headed bolt can now be turned to allow water into the heating system. Refill to 1-1.5 bar. Remove key when finished. If the key is missing, a plumbers merchant will be able to get you a replacement.
