Worcester 35 CDi Leak
6 Jan 2008
Middlesex
I have an old Worcester 35cdi. Last Xmas it went a little crazy and needed most of it's cards replaced. Which forced me into a homecare agreement with British Gas.
The agreement ran out last week, and this week it has decided to spring a little leak. Nothing more than a drip at the moment.
Looking at the schematic I have come to the conclusion that the leak is from a screw known as the Bypass Adjuster. Is this a common fault? Would it be cured if I replaced with a new bypass adjuster, as I assume it has a washer of some sort which is failing. Can I just adjust it. It also has a circlip at the bottom of the thread of the pipe. Should this be tight with the screw? Has it fallen? Is there a piece missing?
Cheers for any help.
28 May 2004
had same problem just put some ptfe tape around it will have to drain boiler first then.count the turns on it when removing it and the same cont screwing back on.
6 Jan 2008
Middlesex
Cheers.
How precise do the turns need to be?
Is it possible to replace the adjuster screw? Would the PTFE tape be considered a permanent fix?
28 Jan 2005
London
that would be a real botch job, get it repaired properly; the bypass is an important part of the system
28 Jan 2005
London
i would expect a build up of dirt and limescale, which needs cleaning.
you can usually get repair kits for this sort of stuff; pakking, oring that kind of thing.
it then needs setting; too much bypass and the heating does not work well, too little bypass can damage the boiler
