worcester 9.24 central heating combi
M
mckinnon100
hello all. need some help.
i have a combi boiler that take a lifetime to fire up. at the last count it took 90 odd tries and then it eventually lit the pilot light.
can anyone tell me what the problem is?
when the combi is not on i cannot see a pilot light light. is this unusual?
many thanks for your help
26 Jun 2004
London
There are all sorts of faults that can affect your boiler which I must say is already well past its normal life expectancy.
Most people get their boiler serviced every year and if there is any problem in between services they call an engineer to fix it.
If the boiler is able to work then there is probably not any very serious problem apart perhaps from a failing diverter valve.
You need a competent engineer to come and sort it out for you.
Tony
S
Soggy_weetabix
a Heatslave per chance?
Very easy Worcesters to work on as every job is soooo simple.
The sight glass will restict the view of the pilot on a boiler this age.
NO BOILER IS TOO OLD
Dave
2 Mar 2007
Lancashire
Ignitor worn/shot.
A good service will cure this.
Agree soggy but these things are nearly as old as you and only one day younger than God :LOL: .....Only jesting ;)
1 Sep 2006
Would love to get a job on a 9.24. Think they have all but gone around here.
Great boilers but yes they are old now. Can still get alot of bits though.
OP is it the electronic or does it actually have a push button and spark for a pilot light.Are you saying you can hear it sparking to try and light the pilot??
Stan
26 Jun 2004
London
Not many parts officially available!
Fan is discontinued BUT looks just like the motor and impeller from a netaheat if you are stuck!
Also the o/H stat is not listed any more.
Quite solid if anyone is determined to keep them going.
Tony
M
mckinnon100
thanks all,
hello pannierstan. in answer to your question yes its electronic. i did have a service done on it a few months ago but he said i needed a new combi. it would cost £2000. i didnt trust him unfortunately.
when i look thru the glass there is no pilot on at all. when it fires up i can see the gas flame.
any diy i could do on it?
thanks
6 Sep 2005
Clackmannanshire
I agree with CLF, sounds like your HT lead is shorting (ie the spark isn't getting to where it should be to ignite the pilot) Unfortunately as this involves opening the combustion chamber it is a job for a CORGI.
Incidentally I have loads of 9.24 electronics around our area (C.Scotland) and they are all going strong however the Altecnic Exp. Vessel is like gold dust around here.
1 Sep 2006
mckinnon100 said:
thanks all,
thanks
Is a job for a corgi really but point them in the direction of ignition lead/probe problems or just blocked pilot.
Stan
M
mckinnon100
thanks guys. big help.
penpusher, what is a Altecnic Exp. Vessel. thought it was a type of holy grail after watching the da vinci code. lol
pannierstan, i paid the corgi guy £80 a few months ago for a service only for him to tell me i need a new combi. any advice with regard to asking for discount on his next call or should i get someone else.
thanks much
26 Jun 2004
London
You need somebody who repairs boilers who does not have a vested interest in replacing it.
Some people like me just repair boilers so we have no axe to grind.
Most services are only £45-£65 on a combi boiler so £80 is rather on the high side.
Tony
6 Sep 2005
Clackmannanshire
Altecnic vessel is the big red circular drum inside the boiler and right now it's rarer than the holy grail around here, it is the main cause of breakdowns on this appliance at the moment
26 Jun 2004
London
We have one in stock!
Not because we want to but after ordering it for a client she is more than satisfied with the expansion vessel radiator that I was so stupid to set up for her as a temporary measure!
Tony
