Worcester Danesmoor 15-19 Coil removal
25 Nov 2013
Dumfriesshire
Is there anybody out there that can offer any guidance on how to remove the coil when the retaining nut just spins?
Thanks in advance.
Just try gently levering the nut up with a thin blade as you unscrew...just to help the threads catch.
John :)
If that fails, cut the nut off with a hacksaw, lift off the coil, and replace the stem & coil - the stem will come out using a 10mm ring spanner new stem is reverse of above, and new coil will have n new secruing nut with it - it would be cheaper to buy a complete pump, and pinch the stem and coil from the new pump, do not fit the complete pump unless you have and know how to use a pressure gauge as new pumps are never pre-set to the correct pressure on a Danesmoor 15/19 this should be 7.0bar (100 psi) :wink:
Hacksaw down through the top of the nut to the height of the stem, then split the nut with a flat bladed screwdriver.
Thanks for the replies.
I have just tried levering it to try and get it to go, but no luck. Have sprayed small amount of WD on and will leave a few hours.
Does anybody know where I can get a cheap pressure guage and fittings just in case I have to fit a new pump (have ordered a pump ready for spares as recommended).
You can get all you need and more from www.heating-parts.co.uk
Do check the existing pump pressure before replacement and set the new pump to the same....otherwise you'll definitely need a flue gas analyser to get the combustion right.
John :)
