I've got an old version of the above boiler and need a wiring diagram for it urgently. the ones available on-line all show 4 relays and plug in connectors. Mine only has 2 relays and no plug in connectors. If you know where I can look at an older diagram please send me a link.
Alternatively can anyone tell me where the pink wire from the control box goes/does?
I've removed the hot water tank and motorised valve as I do not need them. I'm going to run the heated water through a heat exchanger to warm an outside swimming pool and am going to control the temperature via a pipe 'stat.
Any help would be great
