I've just had a single storey extension put in which has made the house quite long, the hot water run to the kitchen tap is going to be in excess of 20metres.. would you recommend a hot water loop? Any Pros and cons? The old run was around 10ish m and that seemed slow.
Also, I did hear that you can have a gravity hot water loop if you know what you are doing but from the posts I could find on here there sounded like there was an issue..
System details: Vented copper cylinder on first floor, cold water storage in loft, condensing boiler.
any help welcomed..
cheers
Trev
any help welcomed..
cheers
Trev
