Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
hi my plumber has run 15mm pipework from 1st floor to ground floor which then feeds 4 rads all doubles 2 * 1000*600 1 1200*600 and 1 1400*600 is this acceptable or should it be 22mm ? any advice would be great.
thanks i'ma bit concerned because the rad on the end of the run is a 1400 by 600 double and we have to have it on max to get it warm sorry forgot to say its a combi vailliant 837
boiler was fitted downstairs with pipework running up to first floor with 22mm pipe for about 1 metre then all rads upstairs and downstairs come from 15mm 10 in total. he has agreed to change upstairs to 22mm but says the feed downstairs in 15 is fine I just want to make sure he gets it right this time.
By doing a total of the output of all the rads on this part of the system, I would say that 15mm is undersized. I would definitely have done it in 22mm.
The output of the 4 rads comes to approx 26,000 BTU, and 15mm is only really good for 15,000 BTU. Therefore, you may struggle to get them to heat up properly.
