Hello all,
I want to pull a light wire through an extremely narrow wall space in between two wooden studs. There is about 15mm width (but +100mm depth) and to make matters worse, there are already 3 cables going through this space. And to make it even more challenging, the cable I want to run is a 3core+cpc, so wider than standard 2core+cpc lighting. Most of the wall is closed, so no way of fitting any PVC trunking retrospectively and no way of pulling out existing cables to redo everything. This run is not 100% necessary, but it would avoid use of another JB buried in the floor or an alternatively much longer cable run...
I think most of the friction simply comes from the cables rubbing against each other while pulling. Has anyone ever tried yellow77 or can recommend any other cable lubricant alternative? Something that does not impact the sheathing of the cables (or the wooden studs it eventually comes in contact with). Yellow77 only comes in large quantities so bit if a waste for the small amount I would use.
Thanks.
Thanks.
