I wonder if anyone has any thoughts on this mystery.
A friend as a Johnson & Starley Economaire 65 which has stopped working on the heating side but still produces DHW.
Two Engineers have looked at it, the first fitted a new gas valve which didn’t make any difference then swopped a working part from the DHW side to the heating side to find it still didn’t work.
The second Engineer, while not finding the fault was of the opinion it could be something small but illusive.
The boiler was installed in 2013
She has been given a quote for the following ...
New Aquair S20 Warm Air Boiler
New Alpha Evoke 28NX Hot Water Boiler
Built In 24 Hour Time Control
Cold-Air Summer Switch
New Heating Pipes To Warm Air Heater
Update Compartment Ventilation
Supply & Fit New Wireless Room Thermostat
Install New 22mm Copper Gas Supply
Supply ET/System/Modairflow
Install Magnetic Filter & Scale Reducer
Install New Condensate Pipe To Discharge
Install New 4" Horizontal Flue Kit
Which would be an expensive remedy if it turned out to be something simple.
Thank you very much for your help.
