Zanussi 1250 drum bearing change
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
From sound and feel it seems drum bearings have gone. Found this advert for bearings and seals not too expensive so worth changing I think.
However I see there are a few Zanussi 1250's listed so a little worried about ordering the wrong kit. And also have a mauled right hand and wonder how hard the job of changing them is?
Washer at moment still running so I have some time to sort it out I have stripped washing machines before I damaged my hand and some were easy others were really hard to work on.
I don't have a bearing puller so not sure what I can lash together to remove them.
Any advise please. I have worked as both a car mechanic and electrician and before damaging my hand would have ploughed right in. But a little more wary now. If likely to be a problem likely would ask my son to help.
Post the machine PNC number (on the door sticker) so we know exactly which model you have.
This is a difficult, time consuming, & economically questionable repair on an older machine. If you have an injured hand on top of things you will really be struggling.
