zanussi washing machine rubber seal round door
1 Mar 2006
London
got a problem, trying to replace the rubber seal between the drum and the door on my washing machine, i took it off to get to the catch where the door clicks into to repair it, as it was loose, i fixed that but can't get the rubber seal to attach at the drum end, there is a round cable type elasticky thing that i presume fixes around it to keep it fixed on, but i don't seem to have the room to place this around properly, help!
does the front come off on this machine if so that will be the best way. First take the door seal off the door opening then take off the front. You will then have access to the outer tub all the way around. Just a liitle puzzled why you took the seal off the drum end
