Zanussi WJS1265W Washer /Dryer Dead
7 Jul 2007
Down
Front panel lights up when buttons are pressed. Machine will do nothing at all.No error codes showing.If interlock faulty can I test interlock on bench or short out wires in plug that connects to interlock to see if machine will run. Two grey, one orange and a black wire run to the interlock. Any other possible fault ?
Solved this myself. Opened up interlock mechanism on bench. Moved solenoid plunger up and down and turned small wheel. Also did it when it wasplugged in and hanging from the machine- dangerous procedure. Machine sprang into life. took no chances and replaced interlock assembly. all working well now!
