Hi there, I've just spent the last couple of hours trawling through the many threads regarding the lovely reliable suprima boilers!
I called a local gasman out t'other week to do a routine service on our boiler as we hadn't had it done since we moved in and it had been a year. Once he had finished he turned it on and it just kept shutting off a couple of seconds after firing up. After checking some connections to make sure he hadn't caused the fault he decided the pcb (which apparently is the new type) was at fault and changed it to no avail.
He then decided the fan assy must be faulty and got a new one, but unfortunately it was the incorrect part as it was for a smaller boiler (-40,50,60 iirc). he is unsure the model of my boiler as the data plate info wasn't updated when the new board was fitted(?).
He tried changing the air pressure switch which made no difference and said that if he purchased a fan assy and it didn't fix it, that i would have to pay as it was a rare part!? Also, he wasn't convinced that is the problem. this morning he tested the fan which was getting a supply up to the point of shutting down (which i guess it would) so it was inconclusive.
So now he has given up lol! he told me to call some1 else as he doesn't have a clue but he didn't check anything else. My question is, is there anything else i could check before calling some1 out? I've noticed that the water pump is running continuously at the mo which i guess could be related? I have also recently bled the system to clean some rads and filled it with fernox cleaner.
Any advice welcomed
Regards
Joel
Any advice welcomed
Regards
Joel
