Well for the Vokera in my flat I can tell you that is simply won't turn on if there's too low a flow<period> I admit that I've got very limited experience in such matters and rather assumed that was normal.Can you give me an example where the MI's say that the minimum flow rate must be maintained all the time?
Just dug the manual out, and there's a minimum flow rate specified - 350l/hr, or getting on for 60l/min, or 1l/second. It has a flow switch (differential pressure across the heat exchanger I assume).
Oh there's that "a" word again - making an "ass" out of "u" and "me". Or just me in this case
Now I expect I'll get a series of "but there are no boilers left on the market that are that <insert derogatory term of choice here> any more" statements. I'd hope not, but I'd not be surprised to find there are.
And for good measure, it only modulates the output when supplying DHW and not CH. When it trips on the CH flow temperature setting, it then has a 3 minute lockout before it will fire again. And in the meantime, it still has the fan running (albeit on low speed) while it pumps warm water through the heat exchanger. Hmm, just like sticking a Myson fan-coil outside Lets just say, that I've learned a lot from this boiler about features to ensure aren't on any future replacement.
