I'm planning on getting some underfloor heating, specifically WarmUp ( http://www.warmup.co.uk/uk/loose-wire-underfloor-heating-system.phtml)
This will be spured off an existing socket. The installation document says 'The electrician must install a dedicated RCD or use an existing RCD'. My consumer unit is RCD protected, will it be enough to use this RCD and use a fused spur or will I need a seperate RCD?
Thanks for your help.
