If I remove the downstairs light to its own switch would this be possible.
http://www.elkay.co.uk/data/files/350A-1 and 360A-1 2 WIRE PUSH & TOUCH.PDF
<photos of double insulated switches>
Well ur I can't see an earth terminal.
John 1 wire is optional.
There would be - is there a wire connected to it? However, Andy's point was that the switch does not appear to have an earth terminal, suggesting that (despite the metal front), it is a 'double insulated' one, therefore not needing an earth connection - even though we can't see the 'double insulated' symbol (a square within a square) in any of your photos.Yes there is earth terminals in both back boxes.Well ur I can't see an earth terminal. John 1 wire is optional.<photos of double insulated switches>
Fair enough. Does that mean that your slave switch doesn't have a 'ring indicator light'?And the optional wire is for a different model. Universal instructions for a handful of switches which mine 760a-1 isn't one, cheers
I would say that all of that is correct/true. As you say, the crucial question is whether the metal cover is likely to come into contact with any conductors - which seems very unlikely. A piece of metal obviously does not become an extraneous-c-p just because it is in proximity to an adequately insulated electrical accessory.I don't think there are double insulated switches, per se. ... If the switch is all plastic as in this case then obviously it cannot be earthed. ... The problem, if there is one, is the metal cover of the switch which just clips on after the switch is fitted. It is the same as if you had an attractive metal cover which clipped over a plastic socket. ... I presume it has been deem unnecessary to earth these covers as it is unlikely that the conductors can come into contact with them.
Interesting. I must say that I find it hard to envisage how the indicator ring could work with only two wires connecting the switches - but maybe they have thought of some clever approach which has not yet occurred to me!I think it does have an indicator ring.
I suppose it depends upon what the 'indicator light' is meant to do. I had assumed (yes, I know!) that it 'indicated' the toggle state of the switch at the master. If that is the case, it would be a bit more complicated than you suggest. If, of course, the indicator light 'indicates' nothing functionally (but is merely a way of locating the button in the dark - being always lit unless the button is pressed), then what you suggest would work.Not hard to do. It's a momentary action trigger to the master switch, so the circuitry of that could be designed to support an indicator wired across the slave contacts and not leak or falsely trigger. The slave indicator going out for a fraction of a second while the button is pressed would not be a problem.
Not hard to do.
The literature appears to refer to both touch and push versions - and I can't work out which the OP has.Remember these are TOUCH switches. I assume its a metal part which the body touches. So you can't earth that part.
I think you need something like this downstairs.
http://www.ebay.co.uk/itm/2-GANG-25...al_Electrical_Fittings_MJ&hash=item58a538f0b7
well 16mm deep maybe more suitable
http://www.ebay.co.uk/itm/Dual-Flus...pplies_Electrical_ET&var=&hash=item4170a6dd95
with your touch switch one side
and a standard switch the other side (operating downstairs light).
e.g
http://www.ebay.co.uk/itm/BRUSHED-C...rical_Fittings_MJ&hash=item4adaeeb4e3[/QUOTE]
Having a manual switch upstairs is what I'm trying to get away from as the touch switches are time delay switches needed as the pesky kids get up and leave the lights on all night long.
