Hi all - I'm new here so please be gentle! I have a problem which I'd love to sort out myself but would appreciate some guidance - I'm no plumber so I'll go an expert if needed. I will try to give you all the relevant info. Our boiler was installed about 8 years ago and has worked fine until now. We still have hot water at the taps and central heating (although it's switched off until I get this sorted). If I run the central heating, pressure rises quickly to max 4 bar, at which point I panic and switch it off! When it's off, the pressure seems to stay at 4 bar. I can bleed off a pint of water at a rad and pressure drops to 2 bar, but when I run the heating it rises up again. The water refill tap on the steel braided pipe is definitely closed. The FAQs seem to suggest a faulty heat exchanger - this means little to me at present, but if it's a DIYable job I will research it and have a bash.
Any advice greatly appreciated!
Steve
Steve
