I have recently had a new Y-Plan installed to an existing boiler (Worcester greenstar 24ri), this was due to the 3 port valve sticking and the pump being quite old.
Now, when the hot water is on the boiler continually cuts out,however if the heating is on at the same time the hot water heats up fine but the radiators then fill with air and water is pushed out of the expansion pipe into the tank.
This then creates excessive banging throughout the house and the radiators then require bleeding.
The central heating works fine without the hot water being on.
Is it possible the pump is pumping in the wrong direction for the hot water only? (piped incorrectly) any thoughts would be much appreciated.
Simon
Simon
