Ah, the answer is "no" then. Should I? Could I?
Yes primary flow into the cylinder is the one.Now that is a new one on me... there's 3 motorised valves that I can see... I'm gonna guess that you mean one that goes to the big cylinder where there's a label marked "Primary Flow"?
Do you hold the relevant G3 qualification John?My money is that the pressure needle will go up to 4 then it will start running. Probably lost some charge from the expansion vessel so you've only got limited expansion capacity left. Ree charging is a simple job for a pro, and is more likely than a faulty vessel.
How hot is the hot water after its been running? Hot then it usually is off the heating? Scalding hot? Or just very hot washing up water hot?
