What do you reckon my chances are in running 2.5mm T&E through existing 16mm OD conduit with an unknown number of bends (but at least 2) ?
You might be able to pull new singles through.2.5mm PVC singles via 16mm conduit
Singles are stranded and flexible. T&E is not.Could you strip the sheath off the T&E where it enters the conduit and pull the cores through as singles?
Flex can be used, although it would be a rather expensive thing and for conduit would still need the outer covering removing, but for a short section probably not much difference.This is fair. Is there any reason not to use flex?
I can't work out exactly what you want to do.My flat final ring circuit is wired using 2.5mm PVC singles via 16mm conduit buried in the concrete slab (apart from vertical runs up walls to sockets). I'm considering running new T&E where i want to split the ring
Why do you want to "split the ring?
Ow will replacing the singles with T/E help?
