I am trying to determine what the method of construction is of this exterior facing wall, so I can then figure out what the possible causes of damp on the inside is.
The building is an 1980's extension to a much older stone built detached property. The extension has stone on the front but on the not so visible side and rear is rendered.
At the bottom of the wall for the first 8" or so there is block work, there is a metal lip, and the render starts.
The has perviously been a leaking guttering, which has been leaking for a number of years, I have now rectified this issue. I want to know whether this leaking gutter was the sole cause of damp on this wall. I don't want to replaster and decorate the interior for the damp issues to persist.
What I'd like to know, is from this description can anyone identify what the construction method is and what, if any, damp proofing it should have.
My guess is that above the block work is breeze blocks, sitting on top of a DPC. But that is just a guess.
Here are some pictures of the transition from the blocks to the render, and the guttering before I fixed it.
![xZo2lNb.jpg](https://i.imgur.com/xZo2lNb.jpg)
![S3wvim0.jpg](https://i.imgur.com/S3wvim0.jpg)
![ua4keZj.jpg](https://i.imgur.com/ua4keZj.jpg)
