- Joined
- 17 Feb 2006
- Messages
- 375
- Reaction score
- 2
- Country
Both bulbs failed at exactly the same time, and there was a bit of a "pop" sound when they did.
There's another fitting on the same circuit, on the same switch, which works fine. I've just put a meter across the leads feeding the fitting and got 241 volts. So I'm assuming that the ballast is kaput.
Replacement ballast seems to be about £35, and is maybe a bit fiddly to replace (are those wires easy to get out and back in?).
How would I rewire this to take LED T5 replacements?
It looks to me as thought it's wired so that it will take two types of bulb - either L and N at the same end, or L and N at opposite ends. But I'm just guessing.
I'm not sure about the colouring of the wires coming OUT of the ballast. Is brown live and white neutral?
As far as I can tell from search all I have to do (hah!) is join all the lives to the live feed, and all the neutrals to the neutral feed.
Or of course I could put a new LED fitting in, but it would look a bit cob, as there is another identical fitting in the same room.
Any help appreciated.
