I'm about to fit a new limestone fireplace surround, the centre part where the hearth is to be placed was already concreted but the hearth is too long and the edges rest on the wooden floorboards.
The hearth has sections underneath that make contact with the floor as seen in the second picture, the middle two supports would rest on the solid concrete, the outer two would be on the floorboards.
Do I need to concrete the whole area underneath where the hearth sits, or could I use some other sort of adhesive to make the base strong enough to avoid cracking should someone stand on it?
I'll only be putting an electric fireplace in there.
Thanks.
Thanks.
