Hi there,
We have a Beko Fridg/freezer. It is about 7 years old. In the last month of so the fridge has started icing up on the inside back wall. The ice only appears on the top half of the fridge section (the bottom shelf and the salad trays have no ice behind them)
Along with this, some food in the fridge gets slightly frozen.
We have never had ice build up of any description in the fridge before. It also seems slightly louder than normal though I can't be 100% sure about that.
We popped into our local fridge repair place and described the problem to him. He said it is almost certainly the gas has gone causing the fridge not to turn off and thus the ice build up and food freezing. He said (and I'm paraphrasing now) the gas "thing" is positioned halfway down the fridge, and as the gas has gone, the "something" doesn't run down to the thermostat, causing the fridge to stay on and the ice to build up from the gas "thing" upwards, hence the ice only building up in the top half of the fridge. He said the gas can be replaced and a new valve put on for £50 but no guarantee can be given to how long this will last before it happens again and we are better off scrapping it and buying a new one.
Can anybody on here backup this diagnosis? Could it be something else, easily fixable or is the gas the likely culprit?
Many Thanks
Greg
Many Thanks
Greg
