its a registered land charge/restrictive covenant linked to the original conveyance for the substation. Our property (and all the others on the east side of the close where the HV cable runs) are caught as part of the subsequent owners clause....so we are all bound up! In the meantime I'm still waiting for the 'local depot' of SSE to come up with their solution......
Update 4th June....no progress! SSE have come back from their wayleaves dept and said "....The cable that has been exposed is at an unsafe depth and therefore the cable needs to be buried to make it safe. Our solution to put the situation right is to raise the levels on top and around the cable as it runs behind the now removed sleepers and underneath the concrete. In order to make it safe, it is likely there will be some adjustment in the way you use the path in its current format."
I have rejected this bodge suggestion, not least because it will make access into our garden much harder...and its a bodge. I have referred it to HSE for advice. I am also engaging our house insurance legal cover.
Ask them for a copy of the Wayleave so you can examine its terms. Insist on the actual original terms signed by the previous owner of your house, showing the date and signature.
Thanks JohnD. I have the original easement which takes the form of a binding conveyance between original owner and Southern Electricity Board in 1967. This was for the transfer of land for the substation at the bottom of the close along with the connecting underground/overground cables, poles and ducts running across the other parts of owner's lane. They say that because the easement says 'approximate route' they can and did stick the cable where they like and its my fault the wall fall exposed the cable. This is a comparison of two images (we are house nearest the pole). Original easment - looks more or less tight to the boundary to me - running north (up) from the pole. The second image is the actual line of the cable...all over the show. Now to me that doesn't look enough of a match to be called 'approximate' as I would think approximate would mean any route within a defined/hatched corridor...otherwise whats the point in having a plan. I'll take other views gladly.
