AEG B2100-4-M Oven problems
1 May 2006
Hi
I have the above oven, recently I've replaced both the element and the fan but now the fan is randomly cutting out.
This seems to be once the oven has been on for a while and when it does stop the heating LED goes out as well which indicates the oven is up to temperature.
I've tried Turing the temperature dial and can hear it clicking which makes me think the stat is working ok but I'm getting the impression there is either another stat?
It's currently stopped at the moment and it looks like the element has stopped as well so the oven got to temperature, something cut out and is now cooling, any ideas?
I left the oven on after it had cut out and after it cooled it came back on, I've ordered a thermal cut out to see if that resolves it.
Any other suggestions welcome
That's the one,cable tied to the wiring harness behind the control panel, it triggers the cooling fan or not in your case then an overheat situation occurs shutting the oven down via a fixed temp. stat. until it cools down.
Perfect, thanks.
I'll look for a YouTube video on it before trying to locate it.
