I tried the link, it showed the user manual which I already have. It said turn of the water and contact customer Service, I was hoping that there would be an easy solution.
code will remain there till you solve your leak problem.there is a float on the base of machine nearest the floor that lifts switch when water leaks on to it.the base can be removed by turning machine on side NOT upsidedown. place large towle on floor. pin pointing leak can be the hardest bit. remember water can traville from the top of machine down . dont forget to UNPLUG machine. best of luck frank
Problems come back. I have found where the water is coming from, there is a plastic pipe coming from the large plastic flat container on the left of the machine tha is not conected toi anything at the other end. On startup water comes out of the end and into the tray, any idea what is causing this.
