Today I drained down my system to add some flush to it because all indicators suggested it was in need...( noisy boiler, kettling etc..not been done for at least 6 years)
On start up the upstairs rads are hot .downstairs cold.......switched off all upstairs rads........downstairs still cold....... there is only one drain....had to be replaced because of age ......system when drained not too bad.
Header tank cleaned and refilled.
Pump working in all 3 settings.Not noisy no bleed here!
Boiler worked well before drain down bit noisy.
Boiler on start up quieter working ok.
After rad experiment...heats up a bit then switches off AIR LOCK?
Any Ideas would be apprieciated!
All valves open and masses of hot water.
Run through archive and notthing seems to fit
